Installing...
Verfasst: Sa 15.11.08 17:18
Dear Tech support,
Last year I upgraded from Boyfriend 5.0 to Husband 1.0 and noticed a
distinct slow down in overall system performance, particularly in the
flower and jewelry applications, which operated flawlessly under
Boyfriend 5.0.
In addition, Husband 1.0 uninstalled many other valuable programs, such
as Romance 9.5 and Personal Attention 6.5 and then installed undesirable
programs such as NBA 5.0, NFL 3.0 and Golf 4.1.
Conversation 8.0 no longer runs, and Housecleaning 2.6 simply crashes
the system. I've tried running Nagging 5.3 to fix these problems, but to
no avail.
What can I do?
Signed,
Desperate.
DEAR DESPERATE,
First keep in mind, Boyfriend 5.0 is an Entertainment Package, while
Husband 1.0 is an operating system.
Please enter command: ithoughtyoulovedme.html and try to download Tears
6.2 and don't forget to install the Guilt 3.0 update. If that
application works as designed, Husband 1.0 should then automatically run
the applications Jewelry 2.0 and Flowers 3.5.
But remember, overuse of the above application can cause Husband 1.0 to
default to Grumpy Silence 2.5, Happy Hour 7.0 or Beer 6.1. Please note
that Beer 6.1 is a very bad program that will download the Snoring
Loudly Beta.
Whatever you do, DO NOT install Mother- In-Law 1.0 (it runs a virus in
the background that will eventually seize control of all your system
resources.)
Also do not attempt to reinstall Boyfriend 5.0 program. These are
unsupported applications and will crash Husband 1.0.
In summary, Husband 1.0 is a great program, but it does have limited
memory and cannot learn new applications quickly. You might consider
buying additional software to improve memory and performance.
We recommend Cooking 3.0 and Hot Lingerie 7.7.
Good Luck,
Tech Support
The same problem seems to exist with another piece of software:
Dear Sir,
Last year I upgraded my system from Girlfriend 7.0 to Wife 1.0 and noticed that the new program began creating problems within the system processing and that took up a lot of space and valuable resources.
Wife 1.0 installs itself into all other programs and launches during system initialization, where it monitors all other system activity.
Applications such as Poker Night 2.3, Girlfriend 3.2 and Saturday Football 5.0 no longer run, crashing the entire system whenever selected
I cannot seem to keep Wife 1.0 in the background while running my other favorite applications. Whichever module or software I enter, only Wife 1.0 seems to run and nothing else.
I am thinking about going back to Girlfriend 7.0, but the uninstall from Wife 1.0 to Girlfriend 7.0 does not work on this program. Can you help me, please!!!
Thanks,
Rajeev
To: Rajeev
Dear Rajeev,
This is a very common problem men users of the Wife 1.0 software complain about but it is mostly due to a primary misconception of the software.
Many men upgrade from Girlfriend 7.0 to Wife 1.0 with the idea that Wife 1.0 is merely a UTILITIES & ENTERTAINMENT program.
Wife 1.0 is an OPERATING SYSTEM and designed by its creator to run everything. It is unlikely you would be able to purge Wife 1.0 and still convert back to Girlfriend 7.0.
Hidden operating files within your system would cause Girlfriend 7.0 to emulate Wife 1.0 so nothing is gained. It is impossible to uninstall, delete, or purge the program files from the system once installed !!
You cannot go back to Girlfriend 7.0 because Wife 1.0 is not designed to do this. Some have tried to install Girlfriend 8.0 or Wife 2.0 but end up with more problems than the original system. Look in your manual under "Worries Invited For Ever (Wife 1.0)".
I recommend you keep Wife 1.0 and just deal with the situation. Having Wife 1.0 installed myself, I might also suggest you read the entire section regarding general partnership faults (GPFs).
You must assume all responsibility for faults and problems that might occur, regardless of their cause. The best course of action to solve this major IT problem of yours will be to enter the command C:\APOLOGIZE.
In any case avoid excessive use of the Esc key because ultimately you will have to give the APOLOGIZE command before the operating system will return to normal. The system will run smoothly as long as you take the blame for all the GPFs.
Wife 1.0 is a great program, but very high maintenance.
Consider buying additional software to improve the performance of Wife 1.0. I recommend you to install the latest gift software like Flowers 2.1, Necklaces 3.2, and Chocolates 5.0.
note: Do not under any circumstances, install Secretary With Skirt 3.3. This is not a supported application; in fact it is a deadly virus for Wife 1.0 and is likely to cause irreversible damage to the operating system.
regards,
Amit.
Boyfriend 5.0.
no avail.
What can I do?
Signed,
Desperate.
DEAR DESPERATE,
Loudly Beta.
resources.)
Good Luck,
Tech Support
Dear Sir,
Thanks,
Rajeev
To: Rajeev
Dear Rajeev,
regards,
Amit.
